1 - 16 of 16 Posts
Have the following for sale near Pittsburgh, PA.. Will ship for actual shipping cost. PayPal.
1. Split bench seat - briar brown. Drivers seat worn and has a cigarette burn (see pics). 1984. Or Will sell parts. $130
a. Headrests $35
b. Seat back side chromed plastic trim $30
c. Center arm rest $25
d. Seat belt guides - brown $30
2. OEM front license plate mount. $35
3. Seat track end covers. 1986 $20
4. Seat belt guides. Maroon. Need re-painted. I can paint with SEM black if desired. 1986 $30
5. Radio from a 1986. Has 4 speaker wires soldered to radio receptacle (see pic) $30
6. Radio from a 1984 $30
7. Carb from 1984. Rochester 4bbl $40
8. Seat tracks. Need cleaned up and one foot repaired. 1978 $30
AFC894F2-8890-4E32-8DFA-4764078D9A2A.jpeg B6F6D40E-8E66-4C66-8A6F-6B7621E67BBA.jpeg 3D655FC3-7010-403B-98EF-7E5CEE4F5C86.jpeg B0D2E7F1-338F-46E0-ADFD-9A6F97BBAFD9.jpeg 6B5FF797-7252-489D-9151-C7DE65571795.jpeg 2C2EB597-8AB6-41E8-BF23-095E4C09898A.jpeg A97F89F5-0DD6-47AB-BEAF-B69FC6B61566.jpeg E255D289-1102-41A4-81ED-AD302FE0941E.jpeg 5837E739-AF77-45BF-9B5B-E85F493AB54D.jpeg 6ABA00EC-E0CA-4294-913A-B981879DD76C.jpeg
pm for additional pics
1981 400 4-Speed
I am interested in the OEM front license plate mount. $35
Assuming from your pic it will fit a 78-87 El Camino......?
I am interested in a radio. Have a 1986 and would prefer to use the stock connector. Can't tell from the pic if the wires could be "de-soldered" or the 1984 would work. I am 0 for 3 so far on used G-body radios from the junkyard. Do you know if the radio and tape players work ?
Discussion Starter · #7 ·
Both are no tape player - just am/fm. The 1986/7 is 1.5 DIN size which fits a large rectangular cutout. The 1984 is single DIN with knob on each side of the smaller rectangular opening. Requires a different escutcheon and different mounting, Both radios work.
The wires on the 1986 could be de-soldered and edge connector cleaned up if you are good with a soldering iron and de-soldering braid. Would be much less work to strip some insulation off of the harness speaker wires inboard of the connector and solder the radio leads there. The harness connector would not be used but also would still be there If ever you wanted to change the radio again, These are just my thoughts.
Discussion Starter · #9 ·
listing has been adjusted.
1. Split bench seat - briar brown. Drivers seat worn and has a cigarette burn (see pics). 1984. $120. Or Will sell parts as listed below:
a. Headrests $30
c. Center arm rest $20
d. Seat belt guides - brown $20 or I can prep and paint with SEM black if desired for $25
4. Seat belt guides. Maroon. Need re-painted. I can prep and paint with SEM black if desired. 1986 $25
5. AM/FM Radio from a 1986. Has 4 speaker wires soldered to radio receptacle (see pic) $25
6. AM/FM Radio from a 1984 $30
7. Carb from 1984. Rochester with spacer and linkage $304bbl $30
8. Seat tracks. Need cleaned up and one foot repaired. 1978 $25
Discussion Starter · #11 ·
pic of the 1984 plugs, back of radio, and label on the radio. As you can see the harness had these spliced in. They are included with the radio.
E3F8400F-204B-41FA-98CA-94E8E1B8FBD7.jpeg E5F7E09D-501B-4D74-9E98-7E088F6B4A7C.jpeg D830A784-289B-4643-85A2-787482B8226B.jpeg
[QUOTE = "James6406, publicación: 2550609, miembro: 92769"]
Tenga lo siguiente a la venta cerca de Pittsburgh, PA .. Se enviará por el costo de envío real. PayPal.
1. Banqueta dividida - marrón brezo. El asiento del conductor está desgastado y tiene quemaduras de cigarrillo (ver fotos). 1984. O venderá repuestos. $ 130
una. Reposacabezas $ 35
B. Detalles de plástico cromado en el respaldo del asiento $ 30
C. Reposabrazos central $ 25
D. Guías del cinturón de seguridad - marrón $ 30
2. Soporte de placa de matrícula delantera OEM. $ 35
3. Cubiertas de los extremos del riel del asiento. 1986 $ 20
4. Guías del cinturón de seguridad. Granate. Necesita volver a pintar. Puedo pintar con SEM ***** si lo deseo. 1986 $ 30
5. Radio de 1986. Tiene 4 cables de altavoz soldados al receptáculo de radio (ver foto) $ 30
6. Radio de un 1984 $ 30
7. Carbohidratos de 1984. Rochester 4bbl $ 40
8. Asiento de pistas. Necesita limpiar y reparar un pie. 1978 $ 30
View attachment 137531 View attachment 137534
pm para fotos adicionales
[/CITA]
Hola necesito: B y D
thanks
1981 400 4-Speed
I just wanted to post up here. Often we get a bit nervous dealing with forum members with relatively low post counts. But I'm here to say I took the leap of faith and bought from James. The part was exactly as described, he was willing to work with me, and answered every single message I sent him. Nothing but good things to say.
Thanks James.
1 - 16 of 16 Posts
