I have a 78 and the volt meter always reads about 8 to 10 volts. If I put on a meter on the battery it shows 13+ volts, so I know that the alt is working. A while back I had the gauge checked and it was OK. I am thinking that the circuits(strip)that feeds the gauges are the problem. The other gauges work. Has anyone run into this or have any suggestions? The way the gauge reads, I always wonder if the alt is working or if my battery is going down.
Any comments greatly appreciated.
elamott
Check for bad grounds on your dash cluster, under the dash to the left side near the fuses, on the left rear of the engine (cable from the firewall), or the ground connection from the battery to the engine (probably on the alternator bracket).
Well, since it's 34-years old (hmmm, that's younger than me :smileyb:) you Might want to check the gauge where it fits into the strip. Go to Radio Shack and buy some contact cleaner and spray around the gauge while wriggling it as best you can. Make sure the cleaner has thoroughly evaporated before checking it out. It kinda sounds like the gnd post isn't making good contact on the meter.
