Storm is coming. I grabbed some BBQ and groceries. Locked up for the weekend so I plan to install the shortened driveshaft after popping in the GV unit a couple weeks ago. I should make some momentum this weekend, but I had to cut out the exhaust pipes to fit the GV, so wont be back on the road for a month or so.
I also plan to add in the PCS electronic shifter, but I want to test the GV with the column shifter before adding in a new varible. I am struggling to get the steering wheel I want, but I finally got a mock-up that I am excited about. This will include the PCS paddles and option for four buttons.
You can read more on my modz page. But here is a mock up of the steering wheel. This is a paper cutout blown up to actual size. The buttons will be auto/man seitch for GV in upper left, OD switch for GV on upper right, line loc on lower left (coming later) and ejection seat button on lower right. I'm also adding in a short NRG adapter becuase the other issue I have been having is the stck height is too high and it pushes the steering wheel too close to me. So, the Momo Jet wheel has a 1.5" dish and by the time I add in spacers and paddle and the short adapter I hope to have the right stack height. This will be fun if everything works as expected.
This is a Volante 9 bolt steering wheel that I started with. I do not want a stack height any taller than this if possible. But, I am adding in buttons and a paddle shifter which requires the 6 bolt design with top bolt at 12 oclock position.
This was my first wheel attampt. It is a 6 bolt Volante. Dish is too tall.
This is my second wheel attmempt. Dish is the same and I finally discovered that this wheel has a 6 bolt pattern with 11 and 1 oclock positions. I though the 12 oclock position hole was correct, but no. Volante has a rotator plate they wanted to sell me but that add to the stack height and does not resolve the fact that I can see a lot of the paddles behind the wheel. I really want somthing that hides this a bit more. The black on black is nice, but not quite what I wanted.
Here is a mock up of the steering wheel that I think I love. I printed this out on paper to actual size. I then cut out the slots so I can visulize what this wheel will look like mounted on the adapter plate and paddles. It is on order now. This hides most of the paddles. The buttons look nice too. The Momo Jet wheel has a nice thick grip and some CF inserts and button. I plan to use a black annodized bowtie horn button in the CF frame. If it fits. I'm excited to get this all mounted up. But, it has been slow to come together.
