5361 - 5371 of 5371 Posts
I think I had a Vice Grip but not much space back there, ha.
I finally won one. I usually have dreadful luck.
I put her up on ramps and crawled under with some simple green and a wire brush applied the spray did some scrubbing. Put the jet nozzle on the hose and rinsed it off. 30 years of road grime and leaks cleaned up a bit. Knocked some extra weight off her.
Investigated my battery drain issue. Been on going for 3 or 4 months. According to you tube videos I don't have a drain, .030 ma.. But the battery does die if it sits more than 5 or 6 days. Disconnected the alternator and pulled every fuse I could find. Current draw never disappeared. Ordered a battery disconnect for temp repair until I can spend more time with it.
Good luck with that, I'd start under the hood with the relays, most likely one is stuck closed when it's supposed to be open with ign off.
