What is the best route to run the speedometer cable from speedometer to the transmission on a 78 El Camino?
I’d say anywhere away from the exhaust on the drivers side
maybe even put some heat shield around it when it does get near the exhaust
Discussion Starter · #4 ·
Is it better to run the cable down the frame on the driver's side, then go straight to the transmission or is there a better way?
Probably down the frame and over the crossmember? I’m not to familiar with 5th gen anatomy
Discussion Starter · #6 ·
Thank you Josh. I'll get it up on the ramps and give it a try.
Discussion Starter · #7 ·
Since it didn't work the other day, when I disconnect it, I know it's not one line. Is there ways to disconnect it and manually make it run the speedometer so I can tell if the cable is broken?
