..I found this on another web site,this might help ya.:dontknow:.
http://www.cadillacforums.com/forum...leetwood-1985/189789-need-some-info-help.html
http://www.cadillacforums.com/forum...arburetor-cover-1986-fleetwood-brougham.htmlI
The procedure is as follows:
1. Disconnect the TPS and M/C solenoid electrical connectors.
2. Remove the air horn assembly
- Remove the primary side vacuum break hose
- Remove Secondary metering rod holder attaching screw, holder, and metering rods
- Remove Choke lever attaching screw and choke lever
- Remove Choke link (pull up on link and hold intermediate choke lever outward with screw driver; twist link from lever
- Remove Pump link retainer and pump link (do not remove the lever)
- Remove Air horn screws and air horn baffle
- Remove Air horn assembly
- Invert the assembly and remove the TPS actuator plunger
- Remove the solenoid adjusting plug with a center punch
- Remove the float bowl gasket and discard
- Remove the pump assembly (if necessary)
3. Remove the TPS
Installation is as follows:
1. Inspect the TPS wires
2. Make sure the TPS adjusting spring is located in the sensor cavity in float bowl
3 Install the TPS (push down on the connector and sensor assembly so that the connector and wires are below the bowl casting surface)
4. Install the air horn assembly
5. Reconnect the M/C and TPS
..know it said Caddy,but,It just might ponit you in the right direction..
