1 - 3 of 3 Posts
I have a 600 cfm 4160 Holley Carburetor on my 75 Sprint the engine is a 350. It always has had a slight hesitation when accelerating. Took it to a shop and they worked on the timing and fixed some issues with the carb. When I paid the bill he said it needs a 10.5 power valve in it and that would take care of the hesitation. Was wondering if this sounds correct or not.
Holley's website describes what the power valve does and how you determine which one. Seems you take a vacuum reading at idle (in gear with auto trans) and whatever the reading is, divide it in half and that's the power valve you need. I just installed a new Holley 4150 on my 350 (last night) and haven't yet even road tested it, I'll be interested in what you determine.
is this a winter time problem??
depending on your location,
the carb tune will change
or need to be changed a little with the weather..
check the vacuum at idle and part-throttle/ cruise..
I thought this question sounded familiar..
1 - 3 of 3 Posts
