1 - 14 of 14 Posts
QA 1 and others make anti-hop bars for your Camino. Also someone makes a set of slapper bars, seen them on a chevelle at the rod shop.
87 brings up a good point as well.
How are all the rear end bushings ?
Do you have the coils air bags ?
X2, also good shocks. I was there a year ago, after a pair of Spohn upper control arms and UMI lowers, new shocks(not air shocks) I still had no traction but the rear felt like it was still with me and trying to grab!
welcome M
nice lookin Elky
if you have tried everything, and we know very little about what that was ??
everything to you may be just the basics,
or you could know enuff about wheel-hop by now you can write a book,
and teach me / us something, I learn something new everyday..
sometimes a bunch of new aftermarket parts cause more problems if installed
wrong, or just a bad match to the other parts or intended outcome..
if everything is different ??
when did it start ?? between which mods ??
or did you do all the mods at once ??
what kind of mods ??
got any pics of everything ??
where is the pinion angle ??
welcome M
nice lookin Elky
Yea, what JJ said X2
Discussion Starter #9
welcome M
nice lookin Elky
I bought I bought the car about 5 years ago the person who set it up had the ladder bars on it which gave me horrible ride I removed a lot of bars and this all started I put On tubular control arms and I airbag to Springs and put new gas shocks still no luck horrible wheel hop violent any suggestions would be greatly appreciated and thank you to all the other people trying to help
Are your new control arms adjustable? Just checking, possible pinion angle problem? I've also seen a few cases cured by lower control arm relocating brackets like this.
One other thing that's probably not a problem but worth looking into is tire balance. Doing a burnout gets those tires turning fast enough to be going 100mph so just a slight balance problem will be magnified over normal cruising speeds. Just a thought.
Discussion Starter #12
Thks ill try balancing them didnt thk of that thank you
Here is a thread that speaks about wheel hop and pinion angle.
This site has an advanced search feature that can bring back posts.
For example enter keywords "wheel hop pinion angle"
1 - 14 of 14 Posts
