Hi I am new here and I am in the prosess of restoring a 1972 Elcamino and a frend of mine has a 6 speed trans from a 89 corvette and offerd it to me is a bit of a drive to go get it so before I go on a road trip I figured I'd ask some of you folks if it is going to bolt up to my 72 350 block the trans is compleat with bell housing new clutch hydraulic slave and drive shaft
Jerry h.
the 89 is the L98 tpi motor ,which is a late gen 1 chevy it will bolt right up with the exception of the flywheel. the 89 uses the 1 piece rear main seal crank with the smaller bolt circle for the crankshaft flange.luckily the early stick flywheels are a dime a dozen
