Driver's window jerks as it goes down, doesn't get stuck or hesitate just doesn't go down smooth. Goes back up very smoothly. Motor? Regulator? Track? Just the way it is?
Thanks,
Don
some didnt have the dampening spring and get sloppy with age.mine is doing the same thing.i tried a new motor and lubed everything to no avail. i am going to try to put the dapening spring from a malibu door to see if it fixes it if not a new regulator
Mine did jerk gong down, but the new motor fixed the issue. Not an expensive fix to try ( less than $50). Also, a little lithium grease could help, and might solve the problem.
