My 1984 el camino has a wiper problem. I Replaced the wiper switch on directional(cruise disabled) no response from wiper controls, wipers work only on mist if you let go,the wipers stop and you need to try to get the them to park position (press and release till they park. any ideas
I forgot to add
first check the 5wire connector from the switch to the motor at the base of the column..
and you can probe the connector at the motor with a test light connected to ground..
yea the piece in-side the column is the switch..
the turn signal stalk is just the knob for the wipers..
:texas:
