I installed an intellitronix dash kit however I was unable to figure out where i need to route the tach wire to. It says to a part of the coil however it doesn’t specify. If I post some pictures of the coil and instructions could someone help?
It is not on the coil it is on the HEI distributor . It is on the right side of the distributor it is the front socket. it might or might not have a wire already in it.
It's the white wire, by the thick pink wire, that goes into the wire bundle. The other end of white wire is a connector that exits the wire bundle at the back of the engine near firewall for connection of the tach.
Related Threads
El Camino Central Forum
892K posts
41.8K members
Since 2002
