41 - 51 of 51 Posts
the wires to the side of the transmission connector should be
for the Lock-up Torq-converter..
should be 2 wires,, power probly from Brake Lite Switch,,
and ground, but the ground could be internal..
the Signal Generator is usually something you have to add to make the cruise work
on older cars without the VSS signal from the speedometer or computer..
the Grey wire from the Cruise control box is not used with a
Signal Generator, it says you use the connector J from the Cruise Box,,
there signal generator has the same connector, probly a 2wire connector..
Discussion Starter #44
The speedometer cable goes to transmission. On the end of the cable there's a device that reads the speed and sends it to the cruise control panel. I would like to know how I can connect the cruise control to the torque converter and get rid of the toggle switch, I'm using to control it. If you know a way to accomplish this, it would be much appreciated.
usually there are pressure switches on the valve body for 3rd and/or just 4th gear,
depending on how its wired up in the pan..
even with the toggle switch it could still be automatic..
do a drive test
see if it un-locks at a stop sign, with the switch on ??
the 3rd or 4th gear switch or the brake switch should un-lock it...
at cruise speed you should be able to feel it or see it on the tach,
it should un-lock just touching the brake/switch..
or some people use
vacuum switches,
or
aftermarket lock-up controllers too..
I think TrannyMike had a wiring setup for a external pressure switch,
on the pressure test port on the case..
ill look at the Rostra instructions again and see if it has
any switched outputs..
Discussion Starter #46
Thanks JJ. Right now I have to have the toggle switch off until it gets over 30 mph or it won't run well. When I slow down under 35 I have to turn it to off, or it runs terrible.
there is a output, but
I have no idea how many wheat lamps or high impedance'sss there are in a gallon of electricity..
i'll look for the TrannyMike post..
from the instructions
"" H.
Orange Enable Output
(ENO) Wire
The ENO Function allows you to use the GlobalCruise
as a driver for an external wheatlamp connected to a V+.
The ENO Wire will drive low when the system is
engaged and to a high impedance state otherwise.
This wire terminates in the harness. ""
well,, the links are gone, pics are gone from the thread,, but here it is,,
its a long thread..
200-R4 Simple Lockup Install
i'm not sure, but I think this is the link..
200-4R Lockup Instructions
yea if yours is on all the time, the external pressure switch is the easy-est
way to go..
screw the switch in, and cut the power wire at the trans, hook it to the switch..
41 - 51 of 51 Posts
