Greetings!
I just joined the forum, starting on a 1968 base El Camino, originally equipped with a 307 C.I. small block V8 and an automatic transmission. It's a factory A/C car, non power steering or brakes. The original engine, trans and A/C parts are missing. Last registered in CA in 1990, but I got it with a clean title. It appears to have been painted yellow originally as far as I can tell, no vinyl top.
At some point the dash was replaced with an SS396 piece, and the SS cluster was included with the car in really poor condition but complete. I also got the SS inside wiring harness as well. Not sure of the rear end ratio, I assume it is a non positraction piece.
It rides on a complete set of Rallye wheels, 15x8 inch in the rear and 14x8 fronts, with all the trim rings and caps.
The plan is to convert the car to a manual transmission of which I have two, both a Muncie M-20 and a Super T-10 w/a new 11" Zoom clutch. I'm installing a fresh 0 hour 350 4 bolt block equipped with World 2.02/1.60 iron heads, speed pro 9.4 to 1 pistons, a single plane Edelbrock intake mounting a Holley 780 carb from a Z-28, a fairly stout Lunati cam and Hedman long tube headers.
The plan is to paint it a shade of forrest green with tan carpet headliner and seat upholstery, black dash and door panels.
Hans
Hans
