'83 305 V8. Factory Gage dash. Everything intact. No Choke light with key on/engine off. Faint choke light when running, Fuse good. Connector cleaned at dash pod mounting. Power to choke coil when running. Engine has good oil pressure.
Ok, I checked my choke oil pressure switch. According to the wiring diagram, one side of the switch should be grounded with the key off. With the key on, engine off, 12V flows through the dash light through the grounded side of the switch and the light comes on.
When it is running, there should be 12V to the other side of the switch and the contacts close sending the 12V through the switch to the choke heater. Since the path through the switch has less resistance than the choke light side, the light goes out.
Anyway, my switch does not close with oil pressure. And neither side of it is grounded at rest (no oil pressure).
I checked some parts stores and all they list is the 2 prong switch for a dash light (part # PS115). This does not have a grounded side. When I tested a new one, neither side was grounded with no oil pressure, so I assume it connects both sides of the switch when oil pressure is applied. While this will make the choke heater function, it will not work the light properly.
So, my question is; does anyone know the correct part number and source for the oil pressure switch for the choke heater system?
Thanks...
A search showed two part numbers, but those came back to the temperature and oil pressure guage sending units, not the choke oil pressure switch.
Thanks...
