Anybody now about matching speakers to receiver?
6.6K views 12 replies 8 participants last post by  Karadjgne
I know this is off base a little but does anyone know what speaker size watts? I need to match up with a vintage Pioneer SX-3700 I just bought? On the back of the receiver it says 45Wps and states that it is a 290 watt receiver. I'm looking for a pair of vintage Pioneer speakers and need to know what model/series # I need to look for! I have a pair of old JVC SK-44's hooked up to it now but they are temporary for now! It rattles those at about 1/2 volume. Thanks! :cool:(y)(y)
#3 ·
Yes, definitely go slightly higher on the speaker impedance rather than lower. A two ohm speaker looks like a near short to the output transistor in the receiver that is expecting 8 ohms impedance. The transistor will flow too many amps of current, eventually overheat and fail.
#5 ·
No home or profesional speaker system (except dedicated subwoofers) is going to be less than 4 ohms & most will be 8. Apparently the SX-3700 was rated at 45 watts RMS (the most stringent rating method) per channel at 8 ohms or 290 watts (145 per channel) "music power" (in 1980!). The JVCs say they're rated for 120 watts music power each, so they're probably being overdriven at high volumes. Just about any quality speaker should handle 45 watts. I'd look for an old pair of Klipsch Heresys myself. I've got an old pair of Pioneer (I think) floor standing 12" speakers that would be perfect, have to look up the model number next time I'm by the lockup. There's also a neat Frazier speaker group on Facebook - Fraziers were a serious competitor to Klipsch in the 60s & 70s, very efficient, made in Dallas, but very nerdy looking. Biggest problem with old receivers is the switches and variable potentiometers (volume, faders, bass & treble) tend to be crusty & unreliable, but if you're electronically inclined they are often replaceable.
#6 ·
Thanks all! (y) (y) That helped! I like the look of the CS-77A's Pioneers and hope to get them at a good price. He has had them since new. The tweeters need to be re-done but still work...I can fix them. They are rated at 65 watts so should be a good match for the Pioneer SX-3700 receiver. I bought the JVC 44's just to have something to listen too in the meantime. They don't hold up well after 4 on the way up to 10. :eek: I'm hoping the guy is local because shipping is a beast on these! Great info! Much appreciated! Thank you all! O.G. :cool:
#7 ·
Careful with wattage, it has to match the type. And there's 3 different ratings. As mentioned there's RMS, which is a distortion free mean, there's Peak which is the full positive amplitude of the sine wave and Peak to Peak which is the full positive and negative sides of the sine.
The better equipment will be rated RMS, so that 45w RMS value is the undistorted value, which will be closer to 70w Peak or 140w P2P. You'll see that a lot in cheap-o car amps, they'll say 1000w, but that's a P2P value to make it sound big and powerful. It's really only 500w Peak or closer to 300w RMS, but even that's a lie, as it's really only the 300w in mono, usually closer to 70-100w per channel.
So when shopping for speakers, they should be rated at @ 50w-65w RMS at 8ohm, and not Peak or P2P.
#12 ·
Many people use car components. A dual 4 ohm sub will wire to 8 ohm. Must be the smaller magnet, more efficient type though Not sure if infinity has their base speakers in dual 4 ohm, but I'd pick them over base pioneers..
There are also suppliers mostly to shops that have replacement components.
