So I’m thinking I might have an issue with my slightly hopped up 350 and I could use some outside input. When I did heads and a cam on the motor I set the initial timing at around 12 degrees with the vacuum advance disconnected. Recently with the price of gas being stupid though I decided to recheck the timing based off the vacuum gauge method I recently heard about. Supposedly using this method you’re supposed to advance the dizzy until it gets the highest vacuum reading and then back it off some. I’m getting a bit mixed here though as the motor seems to get the best vacuum reading at close to 30 degrees initial which is obviously way too much. Am I missing something here?
