painting plastic inner fender wells
4K views 5 replies 4 participants last post by  82 meeno
i have a 78 elky with the plastic front inner fender wells.i want to paint them a semi gloss or satin black.what is best use to clean/wash to prep them for paint?can any one recomend a spray can paint?i want something that will hold up and not peel.am thinking of an engine paint (krylon)?any one paint your radiator shroud(plastic) and wheel humps with spray can paint with good results.i know i need to clean,clean,clean first,but with wth what?
thanx for any advice/replies
#2 ·
I did mine with semi-gloss engine enamel, half-ass job, did not remove them, just masked the hell out of everything... Looks good, but I am going to re-do them with that new Krylon Fusion (plastic paint, I don't think heat is an issue here, but please correct me if I am wrong).. this time I'm taking them out and painting both sides too. Prob will need a wire brush (manually) to get the underside clean and smooth.
It does make a drastic improvement, well worth the limited amount of work
#3 ·
im not to worried bout heat.but what about if i spill coolant(from overflow jar on side).does the fusion paint come in semi gloss?i wouldnt use a wire brush i would think it would scratch plastic.im gonna pull mine off as well.but am thinking of useing some cleaner/stripper.i want to paint my radiator shroud as well.thought of fussion but would like to know if it the most durable paint to use?i would like something that is solvent resistent.
#4 ·
yeah, maybe a vinyl brush or a pressure washer would be better to get the bottom side clean :) Not too sure about the chemical resistance properties of Fusion, but I'll look into it...
I'm not advertising for this particular company, but they show the range of colors
fusion
#5 ·
Fender paint
Spilling coolant will not likely be a problem for your paint. Glycol is generally benign unless you drink a couple of pints of it. The threat would be hydraulic fluid, but that is easy to manage.
As a general rule, you want to consider a Gloss finish since it has fewer pores and is inherently easier to clean and more durable than Semi, or especially Flat. I guess you could clearcoat Flat, but that would defeat the purpose.
If you need to sand it, you'll want to take it down to 400 grit or more, otherwise the rough surface will show right through the paint.
Take care.
