Hey guys,
I have narrowed it down to two different choices for the EL Camino. 1970 El Camino, 396/402, 4 Speed Muncie, 3.73 Gears, Headers, 750 Holley, HEI Ignition.
Choice One: http://www.summitracing.com/parts/lun-10110703k
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .542/.554
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Includes: Cam & Lifters (#71817PR-16)
Or Choice 2: http://www.lunatipower.com/Product.aspx?id=2419
Advertised Duration (Int/Exh): 292/292
Duration @ .050 (Int/Exh): 230/230
Gross Valve Lift (Int/Exh): .544/.544
LSA/ICL: 109/107
RPM Range: 2000-5500
Now i was suggested both of these from Lunati, Im not sure which one will better suit me. I may do the occasional trip to the strip, but its mainly a driver. I have Power Steering and Power Brakes so i want to be able to keep as much vacuum as possible. Im thinking that the 1st one will be a little bit more street friendly.
Please help me out.
Mike
LSA/ICL: 110/106
LSA/ICL: 109/107
Please help me out.
Mike
